4430 front hydraulic pump
IowaJohn
PostPosted: Sat Dec 03, 2011 2:01 pm    Post subject: 4430 front hydraulic pump Reply to specific post Reply with quote
I"m pulling the front pump to fix the leak(s). Will someone please tell me if I have to take the widefront off or not? I"ve done plenty of 4020"s and have always had to pull the WF. Thanks to everyone for your time, John
Tx Jim
PostPosted: Sat Dec 03, 2011 2:04 pm    Post subject: Re: 4430 front hydraulic pump Reply to specific post Reply with quote
IIRC it's easier to remove the fuel tank and radiator than the frt axle to access the hyd pump on a 4430. Hopefully if I'm incorrect someone will correct me.
Ray Tellin
PostPosted: Sat Dec 03, 2011 2:20 pm    Post subject: Re: 4430 front hydraulic pump Reply to specific post Reply with quote
Pull the radiator and lay the condesor off to the side. Remove the 2 plates that cover the pump and pull the pump out the top. An overhead hoist is nice to have for this. Good luck. Also a good time to do the water pump and replace the dampner while your in there.
tim s
PostPosted: Sat Dec 03, 2011 2:27 pm    Post subject: Re: 4430 front hydraulic pump Reply to specific post Reply with quote
Jim, on a 4230/4430 the pump is very accessible from the top, by removing the radiator, on 4630/4840/4440's the fuel tank protrudes over top of the pump to make it a bit harder to get out.
Tx Jim
PostPosted: Sun Dec 04, 2011 3:57 am    Post subject: Re: 4430 front hydraulic pump Reply to specific post Reply with quote
Thanks for the correction. Oh well I was 1/2 right. I guess I've forgotten more about JD's than I realized.
tim s
PostPosted: Sun Dec 04, 2011 7:31 am    Post subject: Re: 4430 front hydraulic pump Reply to specific post Reply with quote
Practice makes perfect is what the old teachers would say,,I don't know about the "perfect" part,but the practice helps sort some problems out for sure...
