AC175 Diesel stopped running
IndianaTom
PostPosted: Mon Dec 19, 2011 6:31 am    Post subject: AC175 Diesel stopped running Reply to specific post Reply with quote
The other week when moving my AC175 Diesel it stopped running and would not start. After bleeding it several times, use of starter fluid and help from my neighbor it finally started. Any one have any idea why this particular tractor stopped running for no apparent reason?
Rich in IN
PostPosted: Mon Dec 19, 2011 7:54 am    Post subject: Re: AC175 Diesel stopped running Reply to specific post Reply with quote
.On most Perkins the final filter has a bleed oriface fitting to let any air that gets into filter to be sent back to tank through bleed return line. Make sure small hole is not plugged, or air will get into pump inlet. C.A.V. DPA pumps will shut down if any air gets to inlet, have seen this happen on several MF tractors over my years of pump repair. Usually engine will restart after bleeding and appear ok.
