SC Case Seals
tomfg
PostPosted: Sat Apr 07, 2012 12:50 pm    Post subject: SC Case Seals Reply to specific post Reply with quote
Anyone have parts numbers or dimensions of the transmission input shaft, and pto shaft (with the motor lift) seals on a 1943 SC Case?
I have the tractor split, and would like to change these two seals, but didn't want remove the seals unless I know I can find new ones.
Thanks, Tom
Pastor John
PostPosted: Sat Apr 07, 2012 1:33 pm    Post subject: Re: SC Case Seals Reply to specific post Reply with quote
Copied from an earlier post
Axle outer seal (replaces felt)
National 413248
Axle inner seal, and also used for brake seals
National 415458
Belt pulley shaft seal
National 474264
Transmission front input shaft seal
National 473215
Clutch lever pivot shaft seal (fits in bell housing)
National 350909
PTO shaft seal (for pto shaft that is “1 3/8")
National 472185
Front engine crankshaft
National 471763 (use two back-to-back to replace old thicker seal)
Mag/governor drive seal
(Chicago rawhide) CR 6935
John Saeli has whatever you need and very reasonable.
tomfg
PostPosted: Sat Apr 07, 2012 2:21 pm    Post subject: Re: SC Case Seals Reply to specific post Reply with quote
Excellent! Thanks John.
chuck machinist
PostPosted: Sat Apr 07, 2012 3:59 pm    Post subject: Re: SC Case Seals Reply to specific post Reply with quote
TECH SUPPORT AT A NOMINAL FEE!
