Painting a S
AZ GARY
PostPosted: Wed Apr 25, 2012 4:06 pm    Post subject: Painting a S Reply to specific post Reply with quote
How much primer and paint should it take to paint a case S tractor.
Bill talbert
PostPosted: Wed Apr 25, 2012 5:06 pm    Post subject: Re: Painting a S Reply to specific post Reply with quote
well that depends on what you are using for a paint gun!! depends on the preparation and varies alot on certian painters!!! two coats of epoxy primer should cover it real well!!!two overall top coats should look good!!!! and i do paint tractors so!!!!!!!
AZ GARY
PostPosted: Wed Apr 25, 2012 6:03 pm    Post subject: Re: Painting a S Reply to specific post Reply with quote
I've never painted a full size tractor and I'm using an acrylic paint. So how much paint would you recommend I buy. I can get it mixed here locally so I can get more if needed. If I need a couple of quarts each then I suppose it would be cheaper by the gallon. I'm using a top feed gun.
JimEvans
PostPosted: Wed Apr 25, 2012 6:23 pm    Post subject: Re: Painting a S Reply to specific post Reply with quote
About 5 quarts to be safe.
Bill talbert
PostPosted: Wed Apr 25, 2012 7:18 pm    Post subject: Re: Painting a S Reply to specific post Reply with quote
Gallon of epoxy primer sealer! Gallon of topcoat!! I use ppg omni line of sealer and paint! Paint is a urethane! It turns out with a wet look! Tons of shine! !!! Get tech sheets on the products!! Ease use a good respirator! !! Good luck
