5610 starter drive?
AlanBarrett
PostPosted: Sat May 12, 2012 3:02 pm    Post subject: 5610 starter drive? Reply to specific post Reply with quote
Where can one buy just the starter drive? There was a bad spot on the ring gear for a few years. The clutch finally went out so my bro-in-law replaced the clutch and had new ring gear installed. Soon the starter started then same thing again. When trying to crank, the starter would grind. Eventually it would grab and start. I purchased another starter from local New Holland dealer. Pulled the old starter and inspected the ring gear. The area was about an 1/8, or less, of the overall diameter. What would cause this? Could the damaged area be cleaned and beveled? The starter motor is ok, drive is eaten up.
View user's profile AIM Address MSN Messenger
RodinNS
PostPosted: Sun May 13, 2012 12:11 am    Post subject: Re: 5610 starter drive? Reply to specific post Reply with quote
You can easily buy the drive from NH IF you have an original or equivelant Lucas starter. If you're got one of the repop indian made starter then you probably can't buy a drive... at least not as easily.
With that said... it may still be cheaper to buy an entire repop starter than a drive for SOME of the OEM Lucas starters.
Rod
AlanBarrett
PostPosted: Sun May 13, 2012 4:22 am    Post subject: Re: 5610 starter drive? Reply to specific post Reply with quote
RodInNS wrote:
(quoted from post at 14:11:05 05/13/12) You can easily buy the drive from NH IF you have an original or equivelant Lucas starter. If you're got one of the repop indian made starter then you probably can't buy a drive... at least not as easily.
Rod
The starter I got from NH was (I think) a reman. Having said that- I think we are going to use the starter from my 3000 (tore down for rebuild) and save the reman. He touched up the ring gear damage with a Dremel. I did find 2 drives on this site. I guess we will play it by ear and see how it goes.
RodinNS
PostPosted: Sun May 13, 2012 7:53 am    Post subject: Re: 5610 starter drive? Reply to specific post Reply with quote
There's half a dozen different drives for those starters even though the entire starter will interchange. If you order a drive you need the correct one for the particular starter fitted.
I'm not knocking this site... but for something like that you're probably better off buying a drive in person where you can compare new vs old to make sure they're the same.
Rod
AlanBarrett
PostPosted: Sun May 13, 2012 8:47 am    Post subject: Re: 5610 starter drive? Reply to specific post Reply with quote
The problem there is- I doubt my brother-in-law knows which drive came on the tractor.
Now I am wondering if the wrong drive caused the ring gear to get eaten up. The damage is confined to just one small area on the ring gear. He replaced the ring gear when he replaced the clutch. The ring gear that came off was the same way!
RodinNS
PostPosted: Sun May 13, 2012 9:39 am    Post subject: Re: 5610 starter drive? Reply to specific post Reply with quote
That is possible...
Another thing to check... the penetration of the drive is adjustable to some extent by adjusting the eccentric pin that the drive actuator arm pivots on. It's possible that it's not penetrating quite far enough.
Rod
AlanBarrett
PostPosted: Sun May 13, 2012 9:48 am    Post subject: Re: 5610 starter drive? Reply to specific post Reply with quote
Thinking about why engine always stops in the same area. One would think the reason might be that the engine stops on the up stroke of one of the pistons. This could be because the engine does not have enough centrifugal force to overcome the compression. Does that make sense?
RodinNS
PostPosted: Sun May 13, 2012 4:36 pm    Post subject: Re: 5610 starter drive? Reply to specific post Reply with quote
Those engines will stop more or less in one of three places... all related to the compression stroke of one cylinder or another.
Rod
