hydraulics
svenandersen
PostPosted: Tue Jul 03, 2012 5:58 am    Post subject: hydraulics Reply to specific post Reply with quote
Here"s probably a simple question. I just got a JD2640 with a loader. Sometimes the loader struggles to go up, especially at lower RPMs and the bucket slowly tips forward when its loaded with weight. Is it a valve, the pump itself? Other ideas?
Tx Jim
PostPosted: Tue Jul 03, 2012 9:26 am    Post subject: Re: hydraulics Reply to specific post Reply with quote
Many things can affect the performance of closed-center hyd's on JD's.
First thing I would check as far as for lack of speed raising is stand-by-pressure which should be 2250-2350 psi,change hyd filter & clean sump screen. Also look in hyd oil filler hole with engine running,3pt raised for "spraying oil". On the bucket tilting by itself that could be a leaking spool on control valve or bucket cylinder packing.
svenandersen
PostPosted: Tue Jul 03, 2012 10:24 am    Post subject: Re: hydraulics Reply to specific post Reply with quote
Thanks for your advice. All good ideas to follow up with.
Best,
Sven
buickanddeere
PostPosted: Tue Jul 03, 2012 1:10 pm    Post subject: Re: hydraulics Reply to specific post Reply with quote
Where are the loader hydraulics connected to the tractor? When was the last time the trans screen and filter were serviced?
cannonball
PostPosted: Wed Jul 04, 2012 4:33 am    Post subject: Re: hydraulics Reply to specific post Reply with quote
can you give more information on tractor...reverser, high-low what clutch does it have...do you have foot on clutch when the chattering is happening...the tilting bucket can be cylinder bypassing or loader valve bad
svenandersen
PostPosted: Wed Jul 04, 2012 9:10 am    Post subject: Re: hydraulics Reply to specific post Reply with quote
Its a 1980. There is a hi-lo lever left of the steering wheel. On the floor, theres two shifters, one for hi lo- reverse. The other is 4-speed range. The loader hydraulics plug in underneath on the right side, approx below where your right foot would rest. The loader labors and is jerky and seems worse with some weight on it. Sometimes it sems to be better if I increase the RPM. It doesn't make any difference if I have the clutch in or not.
svenandersen
PostPosted: Wed Jul 04, 2012 9:11 am    Post subject: Re: hydraulics Reply to specific post Reply with quote
The loader connections are underneath on the right side, about where my right foot would rest. I got it from a dealer so I don't know the history.
Thanks
buickanddeere
PostPosted: Wed Jul 04, 2012 10:16 am    Post subject: Re: hydraulics Reply to specific post Reply with quote
Assuming then the loader has it"'s own joystick control and has no connection to the scv connectors. That is two positive facts.
The oil must return into a ported filter cover, not just dumping straight into the transmission case.
Ensure there is no flow through the return line from the joystick when the loader is not being raised or lowered.
Should do a pressure test on the transmission pump circuit to ensure no internal leaks. Contaminated oil and plugged filters will hammer the oil lines and/or make valves stick.
Any noise from the front pump coupler/drive shafts.?
svenandersen
PostPosted: Wed Jul 04, 2012 8:08 pm    Post subject: Re: hydraulics Reply to specific post Reply with quote
Thanks,
I'll check and get back to you.
Its been really hot here to work on the tractor
