#5 Mower set up question
EdM
PostPosted: Wed Oct 03, 2012 1:46 pm    Post subject: #5 Mower set up question Reply to specific post Reply with quote
Restoring this oldie and need to know what determines how much to shim the drag bar on each end of the yoke.
Ralph Bauer
PostPosted: Wed Oct 03, 2012 8:08 pm    Post subject: Re: #5 Mower set up question Reply to specific post Reply with quote
Try to get a manual, repair manual. Deere sells them paper or disk (can be printed!), 30,-, or contact Tyler Buchheit, he posts here and also writes for the Green Mag....
James Howell
PostPosted: Thu Oct 04, 2012 6:35 am    Post subject: Re: #5 Mower set up question Reply to specific post Reply with quote
The topic REGISTERING KNIFE gives a detailed description with a couple of illustrations in the operator's manual.
"The knife registers if sections center in guards when pitman is at the inner or outer end of its stroke."
IMG_3472 copy
"Knife is registered by transferring one or more washers from one end of the yoke to the other and by lengthening or shortening the Brace Bar."
Photobucket
"One turn of Brace Bar gives bar 1/8-inch movement."
"When checking knife for register, be sure pitman connections are adjusted as directed."
Photobucket
The parts diagram shows two Yoke Washers, .120 and .036 in front of the Yoke.
There are four Yoke Washers, .120, .036, .060, and .048 on the end of the Drag Bar.
There is one collar shaped like the washers and one round collar on the end.
Hope this helps.
EdM
PostPosted: Thu Oct 04, 2012 7:16 pm    Post subject: Re: #5 Mower set up question Reply to specific post Reply with quote
I have a manual but it makes no mention of this. Thanks for your reply though.
EdM
PostPosted: Sun Oct 07, 2012 7:48 pm    Post subject: Re: #5 Mower set up question Reply to specific post Reply with quote
My bad! I see it now. Thanks guys! My appologies.
