Ford 8340 ?????
Heavyduty1
PostPosted: Thu Oct 11, 2012 12:44 pm    Post subject: Ford 8340 ????? Reply to specific post Reply with quote
Going to look at a 8340 with cab for sale. It has the 16spd trans and the owner says the tractor will not go into reverse or neutral. The owner thinks that the synchronizers are worn out. If I had to split it and replace the synchro's, what's a good estimate for this type of repair?
showcrop
PostPosted: Thu Oct 11, 2012 4:57 pm    Post subject: Re: Ford 8340 ????? Reply to specific post Reply with quote
16 speed is SLE with electronic power shift it could be as simple as exterior elec. connections or solenoid.
Heavyduty1
PostPosted: Thu Oct 11, 2012 6:16 pm    Post subject: Re: Ford 8340 ????? Reply to specific post Reply with quote
showcrop wrote:
(quoted from post at 01:57:01 10/12/12)
Thanks for the reply. I plan to check out the 8340 on Friday.
RickB
PostPosted: Fri Oct 12, 2012 1:41 am    Post subject: Re: Ford 8340 ????? Reply to specific post Reply with quote
Depending on the tractor build date, the F/R synchro alone could run either $1200 or $2800. And it is a long ways in and a long ways back out to replace one.
Planning on a maladjusted cable and learning you have a failed synchro could lead to buyer's remorse.
Heavyduty1
PostPosted: Fri Oct 12, 2012 10:15 am    Post subject: Re: Ford 8340 ????? Reply to specific post Reply with quote
RickB wrote:
(quoted from post at 10:41:05 10/12/12) Depending on the tractor build date, the F/R synchro alone could run either $1200 or $2800. And it is a long ways in and a long ways back out to replace one.
That's what I'm hearing about these tractors. Thanks for the info. Cool
Heavyduty1
PostPosted: Tue Oct 16, 2012 11:26 am    Post subject: Re: Ford 8340 ????? Reply to specific post Reply with quote
Anyone have a tech manual that they would recommend me to buy for this 8340?
Brian Allen
PostPosted: Tue Oct 16, 2012 2:24 pm    Post subject: Re: Ford 8340 ????? Reply to specific post Reply with quote
Heavyduty1
I buy mine from "fleabay", I've had good luck - so far!
Brian
View user's profile AIM Address Yahoo Messenger
Heavyduty1
PostPosted: Tue Oct 16, 2012 2:57 pm    Post subject: Re: Ford 8340 ????? Reply to specific post Reply with quote
Brian Allen wrote:
(quoted from post at 23:24:03 10/16/12) Heavyduty1
Brian
Thanks for the info Brain. I'll see what's goin on. Cool
