1370 hydraulic outlet trouble help please
jllw
PostPosted: Tue Oct 16, 2012 5:46 pm    Post subject: 1370 hydraulic outlet trouble help please Reply to specific post Reply with quote
the outlets on 1370 are working sometimes and sometimes not any suggestions ?? all other hyd functions seem to be ok lift steering trans
Brokengun
PostPosted: Wed Oct 17, 2012 8:18 am    Post subject: Re: 1370 hydraulic outlet trouble help please Reply to specific post Reply with quote
Can you please give us a little more information?
When you say the hydraulics at the outlets don’t work all the time are you referring to when it lifts or when it lowers an implement such as a disc?
I am having trouble with my 1370 at the present time when I go to lower a heavy implement such as a disc it sometimes stays in the raised position.
When I move the lever to lower it acts like the thing is stuck. But if I move the lever very slowly and allow the cylinder to bleed down I can lower the implement.
I’m convinced my problem is in the outlets themselves. The hydraulic outlets are worn out and the back flow pressure over-comes the spring in the outlet.
I have been looking for an outlet with #10 female O-ring fitting to replace it. So far all I can find are ½ pipe and #8 outlets. I guess I will be forced to pay CIH prices
1370rod
PostPosted: Wed Oct 17, 2012 6:41 pm    Post subject: Re: 1370 hydraulic outlet trouble help please Reply to specific post Reply with quote
Almost always the problem you guys are explaining is a incorrect or worn male coupling. Ussually incorrect, simply try a new or correct one and problem should be gone. Alot of the older pioneer do plug in but work exactly as the problem you have described. Rod.
