Cockshutt Puller Carb Question
NaturalPuller25
Guest
PostPosted: Thu Nov 08, 2012 7:50 am    Post subject: Cockshutt Puller Carb Question Reply to specific post Reply with quote
Building a 3400 Hercules. Would a Stromberg 9 with a custom made intake work? Engine will be 401ci and wanting our rpm range to be around 6-6,500. Any suggestion would help. I also have a 4 barrel updraft Zenith I could use if better.
gtx1967jewison
PostPosted: Fri Nov 09, 2012 8:27 pm    Post subject: Re: Cockshutt Puller Carb Question Reply to specific post Reply with quote
You can rarely get by turning a 400 inch v-8 at that rpm. Good luck with that lol
G3400
Guest
PostPosted: Sat Nov 10, 2012 8:05 am    Post subject: Re: Cockshutt Puller Carb Question Reply to specific post Reply with quote
Why don't you flip the intake upside down and run a 4 barrel that intake goes both ways. Fuel injection is another option at that rpm.
Pale Rider 570
Guest
PostPosted: Mon Nov 12, 2012 7:44 pm    Post subject: Re: Cockshutt Puller Carb Question Reply to specific post Reply with quote
Both would work, Stromberg is better though. Do you have to run an updraft? If your making a manifold anyway put a 4 barrel Holley on it if your allowed. You can get it to turn those RPM"s but it takes work, and it will be harder with the updraft.
NaturalPuller25
Guest
PostPosted: Tue Nov 13, 2012 4:13 am    Post subject: Re: Cockshutt Puller Carb Question Reply to specific post Reply with quote
Yeah, we have to use an updraft carb. What is the realistic rpm with the updraft? Is 6 possible? What do we have to do?
Pale Rider 570
Guest
PostPosted: Tue Nov 13, 2012 10:06 am    Post subject: Re: Cockshutt Puller Carb Question Reply to specific post Reply with quote
I would say a pretty stock motor, with a big updraft should run 5-5500, obviously depending on what gear your in. As far as what you can do, lots of things help, head flowed, light pistons, aftermarket rocker arms, etc. If you have other questions send me an email.
Pale Rider 570
Guest
PostPosted: Tue Nov 13, 2012 10:07 am    Post subject: Re: Cockshutt Puller Carb Question Reply to specific post Reply with quote
kingswaysign@sbcglobal.net
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling All times are GMT - 8 Hours
