Ford 2000 Offset
Goto page Previous  1, 2, 3, 4  Next
daverd4
PostPosted: Sat Jan 12, 2013 7:05 pm    Post subject: Re: Ford 2000 Offset Reply to specific post Reply with quote
Moron WOW!!!! It's a OFFSET!!! 2000 I'll take a picture of the serial number tomorrow. Here's A picture of the D#@# Tractor
Sean in PA
PostPosted: Sat Jan 12, 2013 7:14 pm    Post subject: Re: Ford 2000 Offset Reply to specific post Reply with quote
Ok, it's a 4 cylinder offset. Where on the tractor did you find those numbers that you posted?
daverd4
PostPosted: Sat Jan 12, 2013 7:58 pm    Post subject: Re: Ford 2000 Offset Reply to specific post Reply with quote
Heres the numbers. Maybe someone thats not a MORON can figure it out.
daverd4
PostPosted: Sat Jan 12, 2013 8:16 pm    Post subject: Re: Ford 2000 Offset Reply to specific post Reply with quote
It's a 4 cylinder
Larry NCKS
PostPosted: Sat Jan 12, 2013 8:18 pm    Post subject: Re: Ford 2000 Offset Reply to specific post Reply with quote
I'm going to think outside the box here. Is it possible that Ford built that 2000 Offset into 1966 or later? The third set of numbers in that photo surely indicates a build date of 28th of September 1966 as has been stated. That S/N is high enough to be consistent with that build date.
I have a 4 cylinder 4000 that was built in June of 1965. Without looking, I think its S/N is 64***.
Ford did some inconsistent things in those days, such as putting leftover red parts on my 602 cornpicker that was mostly blue.
I have no explanation for the G suffix on the model number. Only a guess that someone decided if it needed a D suffix for diesel maybe a few of them needed a G suffix for gasoline?????
Sean in PA
PostPosted: Sat Jan 12, 2013 8:23 pm    Post subject: Re: Ford 2000 Offset Reply to specific post Reply with quote
For a 4 cylinder 2000, that's a very late 1964 serial number, maybe even into 1965, as they did still make the 4 cylinder models into 1965, even though they were still called "1964" models. So if it was made on the same assembly line as the 3 cylinders, after they had started making the 3 cylinders, then maybe the person that was stamping the numbers got confused and stamped 3 numbers on that one instead of 2, but that still doesn't explain the G at the end of the model number, or the date code that appears to be a 1966 code, but 21111 would be a 1963 and newer 2000 offset with a 4 speed transmission and non-live PTO. Is that the transmission that it has?
Another possibility for the 3 numbers is that the transmission was replaced at some point and that date code was the date that the replacement transmission was made, and whoever stamped it at the dealership when the transmission was replaced stamped the G at the end of the model number by mistake.
Sean in PA
PostPosted: Sat Jan 12, 2013 8:26 pm    Post subject: Re: Ford 2000 Offset Reply to specific post Reply with quote
You may be right Larry, if someone was demanding enough and was wiling to pay enough, they might have built a 4 cylinder 2000 offset in 1966 as a special order.
daverd4
PostPosted: Sat Jan 12, 2013 8:31 pm    Post subject: Re: Ford 2000 Offset Reply to specific post Reply with quote
Well that's thinking out side the box for sure but that is possible about the G wonder if anyone else has a G at the end. But isn't that serial number to low for 1966 #74596?
DustinNC
PostPosted: Sat Jan 12, 2013 9:41 pm    Post subject: Re: Ford 2000 Offset Reply to specific post Reply with quote
You could very well have a 1966 2000 Offset. I have 2 late 1965 2000 diesel offsets. Most people believe that the 4 cylinders were only built from late 62-64. Most all pieces on the tractors have date codes. Try to look underneath the generator in the lower corner of the engine block and give us that code. Tony Jacobs is also very knowledgable on the production dates of these tractors as well. I have had several conversations with him about the late production dates and if I remember correctly, he has some original paperwork dating from 1966 about the Offsets still being offered. His contact info is on here, just search for it, or email me and I will give it to you.
Dustin
Larry NCKS
PostPosted: Sun Jan 13, 2013 2:04 am    Post subject: Re: Ford 2000 Offset Reply to specific post Reply with quote
daverd4 wrote:
(quoted from post at 23:31:37 01/12/13) Well that's thinking out side the box for sure but that is possible about the G wonder if anyone else has a G at the end. But isn't that serial number to low for 1966 #74596?
Not at all. 74596 would be consistent with the continuation of the 4 cylinder models that were classified as 63-64 models. Remember the serial numbers on the 6000 were also part of this series, and if memory serves it was built into 1967.
The later thousand series that began as '65 models had a different serial number sequence.
mhb@ufe
PostPosted: Sun Jan 13, 2013 4:54 am    Post subject: Re: Ford 2000 Offset Reply to specific post Reply with quote
Using the codes from John Smith instead of the 65 and later codes it can make sense other than he doesn't have the G listed.
2=134
1=Ind. and Ag after 1963
11=Offset
1=4 speed with PTO
G=Gas ?
The model code would seem to match your tractor this way even though many of us haven't seen those tractors built that late. Just goes to show that we can all learn from each other if we continue to follow through with gathering information to help each other.
Nice find by the way!
Mark
mhb@ufe
PostPosted: Sun Jan 13, 2013 5:12 am    Post subject: Re: Ford 2000 Offset Reply to specific post Reply with quote
That looks like the starter just ahead of the numbers.
Mark
daverd4
PostPosted: Sun Jan 13, 2013 7:27 am    Post subject: Re: Ford 2000 Offset Reply to specific post Reply with quote
Thanks for all the help those codes are behind the starter where all my 800 series tractors are.So are these 2000's stamped with the same code on the engine and say rearend houseing like a numbers matching car?
mhb@ufe
PostPosted: Sun Jan 13, 2013 7:41 am    Post subject: Re: Ford 2000 Offset Reply to specific post Reply with quote
No, there are date codes cast into many of the parts but they are often different as they identify when that part was cast and the number stamped in the transmission is the date the tractor was assembled.
Mark
daverd4
One other coment someone said the dealer may have stamped the G on it but it sure looks like the factory did it in the picture.Would be interesting to know if anyone else has a G stamped on there tractor surely this can't be the only one.
Page 2 of 4
