JD 60 Crankshaft in a 44 A?
Husker44A
PostPosted: Sun Feb 10, 2013 11:44 am    Post subject: JD 60 Crankshaft in a 44 A? Reply to specific post Reply with quote
Like the title says. Will a 60 crank work in a 44 JD A? Are they the same stroke? Wanting a longer stroke crank before I have the block bored for larger pistons.
2-banger
PostPosted: Sun Feb 10, 2013 12:29 pm    Post subject: Re: JD 60 Crankshaft in a 44 A? Reply to specific post Reply with quote
dont think it will work ..late a crank has same 6.75 stroke as 60 thou
Husker44A
PostPosted: Sun Feb 10, 2013 12:33 pm    Post subject: Re: JD 60 Crankshaft in a 44 A? Reply to specific post Reply with quote
Where would I look for a used Stroker crank? Do you trust used cast pistons?
bobidan
PostPosted: Sun Feb 10, 2013 1:09 pm    Post subject: Re: JD 60 Crankshaft in a 44 A? Reply to specific post Reply with quote
i dont think it will be just a drop in it could probably be done but why? you already have 6.75 in a 44 model.
Larry Baker
PostPosted: Sun Feb 10, 2013 2:36 pm    Post subject: Re: JD 60 Crankshaft in a 44 A? Reply to specific post Reply with quote
thought the governor gear was different also????
2-banger
PostPosted: Sun Feb 10, 2013 6:48 pm    Post subject: Re: JD 60 Crankshaft in a 44 A? Reply to specific post Reply with quote
get a hold of josh blackburn he could make you a 7.5 crank and you wont have to do alot to make it fit
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling All times are GMT - 8 Hours
