I took in a 1951 8N on trade that had been sitting for a long time. Someone had installed a new aftermarket steering box, but never finished the job. Then left it sitting outside with the steering wheel off, and the gear was empty of oil, but for a little grease used for assembly. Water filled the box and rusted everything up. A friend had a box off of a 1948 8N, so, I put it on the tractor. I put new side bushings and seals, and the worm did not have excessive play (up and down), and felt smooth. The wasn't fun to drive at all, even after installing new spindle bushings and thrust bearings. I finally ended up glass blasting all the rusted parts of the aftermarket gear, installed new balls in the spool and other bearing in the gear. Now it drives great and steers easily. I was wondering if all the 1948 original gears are harder to steer than the later models 8N. Tim Daley (I believe) has a nice 1948, and I just wondered if he has the original gear or the later model gear on his, and how does it steer? I did change all the parts needed to make the swap. Dennis
