Dearborn Loader 19-70
I recently got my 1950 8N with 19-70 Dearborn Loader going and have a severe leak coming out of the control valve. Has anyone had any luck with finding repair parts or a replacement control valve? Also, I cannot find anywhere to check the fluid level on the loader. I see the fill port, but not sure if it should be full to the top.
Any help would be greatly appreciated. Thanks...
You can look at the parts diagrams and get
part numbers at link below but pretty much
all parts will be No Longer Serviced.
Therefore you are on your own to
creatively maintain your loader.
Also search web for: Dearborn Model 19-71
Industrial Loader - Owner's Manual.pdf .
You might find some useful info there.
Messicks 19 70 loader
(quoted from post at 13:20:57 09/12/22) I recently got my 1950 8N with 19-70 Dearborn Loader going and have a severe leak coming out of the control valve. Has anyone had any luck with finding repair parts or a replacement control valve? Also, I cannot find anywhere to check the fluid level on the loader. I see the fill port, but not sure if it should be full to the top.
Replace the control valve. New ones are dirt cheap and far better.
TOH
