I have cleaned up the sleeves (narrow flange) from my old backhoe engine and placed them into the purchased block without the O-rings at the bottom. I clamped the sleeves down at 50 ft-lbs torque and measured the sleeve protrusion above the block deck and it is coming out to .001 - .002 inches. Is that enough protrusion or should I shave a little off the block deck to increase the protrusion a bit more?
In a previous post, there was a warning to be careful not to take too much off the block deck because the valve clearance in this engine is quite tight. My question is, how much can be taken off the block deck before there is a risk of valve contact with the pistons? Is there any risk if I take 1 or 2 thou off the block deck?
