Perform Fuel Flow Test, engine cold. Don't start yanking parts off and replacing willy-nilly; not a logical approach for problem solving. Non-starting has nothing to
do with the air cleaner bath oil. Is Sediment Bulb open 2 Full Turns? Are plugs fouled? Loosen the 4 rubber hose connector from carb to air tube intake and remove
hose. Is there fuel in the carb air intake throat? Yes? Float not right. Do not make any carb adjustments. If carb does not pass fuel flow test, there is at least one
obstruction in the fuel system so will require investigating all possible causes with a total carb removal and rebuilding as the last step. If system passes fuel flow
test, move on to electrical. Check for spark. Forget what year you might think you have, it is not important. The important features are if you have the Front Mount
Distributor or the later Angle (Side) Mount Distributor, and whether using the OEM 6V/POS GRN system or a 12V conversion setup. BEFORE you do anything else, I highly
advise you invest in the ESSENTIAL MANUALS and read religiously before doing any work if'N ya wanna be a FORD N-TRACTOR OWNER. If you don't know what system you have,
and what parts are, how can you expect to perform any maintenance? Not trying to beat you up, and my email is open (SEE lower RH for LINK) if you want to discuss
further offline.
CARB FUEL FLOW TEST:
ENGINE COLD! Find a 1-Pint Mason Jar and place it inside an empty coffee can, then position the can under the carb. Loosen the 7/16 hex nut on the fuel line at the
carb brass inlet elbow and gently lift and slide the fuel line off to the side so it points down into the can and jar. Open the Fuel Sediment Bulb Valve 2 Full Turns.
Observe the fuel flow is a steady stream and you fill the jar in 2 minutes. Any sputtering, hesitation, or failure to fill gas in the Mason Jar indicates the problem
is upstream on the Sediment Bulb, in the carb, or in the gas tank itself. If Test passes, connect the fuel line and repeat using the carb drain plug in bottom. This is
an NPT tapered pipe plug thread; it's not a standard thread size, so do not try to use anything other than that to chase threads or replace. If this portion of the
test passes, reset the drain plug, leave it alone, and move on to carb leaking fuel through the air intake port. Remove rubber hose connecting carb to air cleaner
tube. If it is wet with gas the float may be stuck or the level is not set right. The float is brass and soldered on in two halves. If it gets punctured or sprouts a
leak, fuel can fill it and bog it down. Carb Air Intake Throat should be dry. Either way, wet or dry, it is time to pull the carb and get into a total cleaning and
rebuild.
FORD 8N TRACTOR OEM WIRING PICTOGRAMS by JMOR; 6V/POS GRN; FRONT & SIDE MOUNT:
FORD 8N TRACTOR ESSENTIAL MANUALS:
Tim Daley (MI)
