Howdy all,
My father just recently bought a 1953 DC case at a tractor auction, and I'm trying to help him get it going but we have some questions. He had a DC case years ago, was the first tractor he ever bought and bought it at age 12, but has not really messed with one since he graduated high school so he's not sure on a few things on it and I have never messed with one before, only JD and Farmall. This one came with an eagle lift too so we want to use it to run our brush mower as the Ferguson t20 it is on now is just worked to death trying to run it and its lift has that auto plow setup that makes the three-point annoying to use at times.
First off, if anything I ask was asked before, sorry to repeat the questions, but there are a lot of pages to go through here and I'm not finding my answers using the search function.
First question: was the DC case a wet clutch setup? I have seen posts saying that the SC was, so I am hoping this is the case, as we are definitely getting oil in the clutch housing. If not, how bad is that job to do?
Second: When we got the tractor, the clutch throw out forks were bent out. I managed to straighten them somewhat, but was this a common issue and what would have caused this?
Third: both brake pedals are on the right side and there there is a clutch pedal on the left. The linkage is gone for it and there is an added piece of metal to hold the clutch pedal on and some other handy work going on, that makes us question if it was modified to be a foot clutch or if that was factory with some good old farm-hand repairs done on it. With the brake pedals both on one side, does this imply it was factory foot clutch? If not, would this modification possibly be the issue with the clutch fork?
Fourth: I'm seeing a small oil leak on the front of it as well, though I cannot tell if it is the main front seal or the timing cover gasket. Is there a common leaking issue there I can address and how much of a bear is the job of replacing those?
We just got the tractor to my father's farm last weekend so I've not had a chance to even get a manual for it yet, so I appreciate any help or advice that can be given on these questions or anything about the tractor in general.
Thanks in advance!
AWC
This post was edited by AWC on 07/19/2023 at 10:55 am.
Thanks in advance!
AWC
