1963 Ford 4000
Anthony49
Replacing clutch. Never worked on tractors before. Split tractor. Pressure plate springs laying in bottom of trans case. Been dripping oil out bottom of trans case. looks like leaking behind throw out bearing. Are there seals or o-rings behind it and also the output shaft? Is this hard to replace.
Hello Anthony welcome to YT! I have not worked on one of those Fords. In general there is nothing tricky about replacing the seals on the transmission input side of a tractor. It may be possible that gasket thickness or shims may be used to set the end clearance of the shaft. I suggest you acquire a repair manual for your tractor they are very helpful to assure the repair is done correctly. Here is a link to the current manufacturers online parts catalog. CNHI Early Ford 4000 parts Not with the intention of that is where you should get your parts although you can, more just for the diagrams. As far as the clutch the missing the springs you will get a new or rebuilt pressure plate that will have all that on it.
