2440 hyd pump noise
JdJeeper
I have a ‘79 2440 I just got done replacing the transmission pump lines on, both were broken and not allowing oil to be sent to the main pump. After repair the main pump is making a high pitch squeal but when hydraulics are used it is quiet and sounds normal. I don’t know what it sounded like beforehand. I purchased the tractor with the hydraulics not working. Could the destroking valve be sticking sending oil over a relief somewhere??
Have you changed hyd filter & checked/cleaned hyd oil suction screen?
Yes, I have checked both of those areas, the screen was really dirty when I replaced the pto clutch in it and the filter was replaced
