Harry in Ky
- Location
- Central Kentucky
I think we've found the problem with the left brake (as mentioned in my earlier posts on the subject) where it would seem to work with tractor parked and then simply fade away once the tractor started to move. Long story short, I believe all that was caused by sections of brake disc lining material broken off, sliding around, sometimes doubling up and affecting brake piston travel.
It seems the 55 series may have been one of the first series where Deere installed the brake retractor spring assemblies that have been used in many subsequent models. Item #1 in the diagram below. It seems the design of these gadgets will severely limit the amount of piston travel available when brake pressure is applied. When installed, they pretty much have to be in a certain position that allows freedom for the brake disc to rotate within it's limited space while the pistons are retracted. At the same time there has to be sufficient piston travel available to properly clamp the disc between the piston and the reaction plate so as to provide the needed braking action. That travel plus a little bit more to endure the same effect as the disc lining wears down (if it does).
Now for the question. My I&T manual on this tractor hardly makes mention of the retractor spring assemblies, and no mention at all of installation, adjustment or measurement of the piston assembly required in order to accomplish all that. So how do I do that?
My brake repair experience on some later models was such that the manual provided information on the dimensions involved and how to measure the minimums and maximums allowed. Without that, I'm basically just "winging it" here, I guess if I dig out enough measuring devises and spend enough time measuring and calculating, I can probably get it close enough to run, but it might be helpful to know what the Deerecommended proceedure is. I&T certainly didn't provide it.
https://partscatalog.deere.com/jdrc/sidebyside/equipment/60847/referrer/navigation/pgId/390482667
