Today I was at the farm and started my 300 for the first time since I put it away for the winter on 10/21/22. It has a Petronix ignition and ran before the second turn over. This never happened with the points in it. Just thought I would add this since it was 5 1/2 months of sitting.
Second has anyone found a good place to buy a tach. I had replaced this one with supposedly a quality tach and today when I started it, all it would do is jump back and forth. The tach cable broke last fall and I replaced it and it worked ok then. I took the tach out and held the cable end while running the tractor and it never jumped or anything that would cause the tach to jump. I guess for unknown reason, sitting over the winter the tach went out to left field. Or the tach caused the cable to break last fall and now the reason for that is showing up in the tach. In 2016 I got one from this site and it was defective and had to return it. Then I got one from Precision Tractor Parts. Now it seems to have gone to tach heaven. Suggestions!!!
