Dopp Creek
I have a 5000 SOS with two sets of remotes. I was flailing the orchard with a 3 pt mounted mower and when I finished I lifted the
mower to cross the bridge. On the other side, I attempted to lower the mower to mow the lane back to the house but it would not drop
when I lowered the lift control lever. I noticed that when I pulled the lever to the full UP position, the draft control lever would
fall down to the draft position. Tried a few more things but could not set it down. Fast forward two weeks, tractor is in the shed
and the mower is still hanging up. Started the tractor and tried moving the lift lever to no avail. I pushed the aux control valve
IN and the mower raised a few inches. Full OUT nothing happens, but if I feather it in and out about mid-way in I can get the 3 pt to
raise and lower. That's good news because I can drop the mower to work on the tractor, but I'm not sure what's going on. For what its
worth, the hydraulic pump seems to be noisier than I remember. Any thoughts? Again , no response from the lift lever. The only
control is by feathering the ASC valve about mid-point of its travel.
