tomstractorsandtoys
I need away to handle plastic wrap off round bales and silage bag plastic. I use about 200 wrapped bales and 4 200 ft long silage bags per
year. We use to just burn it but the wrap does not burn good and I just never liked the idea. Local township had a dumpster just for this that
was being recycled but the program no longer has any funds. The price of a dumpster looks way to expensive. I have an old Deere 14T square
baler and was thinking of removing the pickup, all the pto driveline parts and the knotters. I was thinking of putting a hydraulic cylinder to
run the plunger and mount a valve on the baler.Then turn it on its side so the opening is up. I was thinking that I could make some wooden
blocks with grooves Like the old hand tie balers. I think you could get good bit of plastic in a bale. I have room in the shed next to the
bales and figure after baled up it would not take up much room and also would not be blowing around. I could then look for a recycling place
or something else to do with it. Any reason why this would be a bad idea? The plunger opening might be a little small but I usually don't have
many big pieces. Tom
