JD 467 baler monitor question
Mshudgins
I am having some issues with my baler. John Deere 467 baler
has about 15k bales on it. When bale is ready to wrap it starts
wrapping but doesnt retract and cut net wrap it just keeps
wrapping. After research on here I replaced my actuator and
wired it directly to the battery. That helped for a while but now
its doing it again. I can bale two bales and it works perfect then
it will not finish wrapping for two bales. Its exactly two then
misses two. Do yall think its my monitor or something Im
missing? Going thru the manual I have plenty of voltage to the
actuator.
My baler is a 459, but probably similar. Make sure your tractor ground is VERY good. I had some trouble with mine acting hokey, and it turned out to be a ground problem.
Welcome to this forum
Ditto on checking electrical ground connection. Have you regularly greased the fitting(item 16) on each end of net knife arm?
This post was edited by Tx Jim on 09/26/2023 at 04:30 am.
Yes sir, it gets greased
I will check my grounds, I did run my power and ground from the
battery up to the monitor.
