Branson 3510H
pilotou
Gentlemen,
Just had a quick question here.....I have a 2007 Branson/Century 3510H tractor with the 1.7l KUKJE diesel engine. Is this same engine in any other branded tractor? I am trying to see if there is an overhaul kit or if I could pull the engine out of another to replace if I had to. From what I understand, I couldn't even order another whole engine from overseas unless it was already installed in something, and parts are extremely expensive.
Thank you in advance.
about the time your tractor was built cummins did a joint venture with kukje and did some design changes to their engines maybe cummins can help you out. kioti tym and kukje make tractors for a lot of the major tractor companies if you can figure out which ones a local dealer maybe able to help
