TFLundyB275
Hi I need help with this.
Recently I had a chance to pick up 2 pairs of Case G1340 wheel weights. Came off a 530CK Loader only with 14.9-24 tires. With research I figured they were correct and would fit on my 530CK TLB with 14.9-24. Weights match what catalogs show are for 24" integral wheels, which I have.
Surprisingly they don't fit, and the tractor it came off of is gone. Dimensionally they fit into the wheel, but the square bolt mounting holes do not line up. In this design it seems one set of the weight holes are for the wheel, the other weight holes is to stack additional weight. Nothing lines up for the wheel mounting.
I measured:
Square holes in the wheel: #1-2= 11.5" #1-3=16.5" (x4 5/8 square, depth from square to outside of rim 8.5")
On the weights, mounting slots: starter-starter(1-3) 11"-14" additional-additional(1-3)=13"-16". 1-2=approx 9".
As you can see, those dimensions show it wont work.
Weights are 18 3/8"OD, 9 3/4"ID, approx 4" height, dished. Inside T slot for starter mounting, outside T slot for additional weights.
Research shows the casting G1340 on the late model 300B/400B with diagrams showing them at least to 580B, all for integral 24" wheels. Seen internet pictures on them up to 580B as well.
Where did I go wrong? Why are these not mounting?
Can a few people please measure the 1-2 and 1-3 mounting holes in their wheels please, listing the dimensions, wheel size, and tractor model?
I'm attaching pictures of my items, parts book diagrams, and one picture of a internet tractor with them mounted.
Thanks in advance.
I measured:
Thanks in advance.
