Poppy Johnny
So, I am still restoring my John Deere 60 All Fuel the manifolds gaskets have blown out the side from age and need to be replaced but my father who is adding in this restoration said that I should consider getting a gas manifold for the tractor for more power.
To reiterate nothing is wrong with the current All Fuel manifold other than bad gaskets, if I swap it out it with a gas model will most likely be put on a wall to be put back on the tractor if for whatever reason I ever attempt to sell the tractor or need to burn kerosene, my problem more or less is that I don't know if the head or anything else needs to be swapped to do that conversion as I really don't want to go through that process.
Personally, I am mixed on the whole ordeal.
