OldCaseNewman
The cutout relay on my 57 Case sparks when it s connected to it s wire from the 12V wire coming from the battery, and ignition switch. Does that mean it s toast? I know it s grounding because when it is disconnected all the other connections on that circuit stop sparking. The circuit originates at the battery terminal on the starter, and that end was sparking too, until I disconnected the cutout relay on the generator.
Also, what are the pros and cons of cutout relays compared to regulators? There s a note in the Brillman catalog that says "due to the modern design, voltage regulators can t be used to charge low or dead batteries. Doing so will destroy the voltage regulator and void the warranty". This tractor came from the factory with a regulator. Thanks for any advice or info
This post was edited by OldCaseNewman on 08/03/2022 at 02:02 pm.
