I have a John Deere 4020 diesel with the original 24 volt generator (Delco 1103026). The generator had an open field coil. After replacing the field coil, the generator will not generate voltage when isolated from the voltage regulator, tractor running, A2 to +24v, A1 to -24v, A2 to F.
With the belt removed, A2 to +24v, A1 to -24v, the generator motors opposite normal rotation. I have tried polarizing with no change. I have reversed the field coil connections with no change. I have tried reversing the test voltage to A1 and A2 with no change in rotation direction.
This generator did not work when I purchased the tractor. What is causing the generator to motor in reverse?
