She was blowing at #4 – but can’t complain too much as the last fix has lasted better part of 20 years. Trouble is now I’m older, and wiser (thanks to this group), and have forgotten exactly what I did all those years ago.
So - took the hood off – didn’t need to but it improves access and gives the opportunity to inspect/clean parts that are usually difficult to reach. Sure enough – gasket shows #4 blown at the 10:30 position. The manifold looks to be in reasonable shape so I’ll re-use, but on the head it’s a different story - I can see & feel the dimple, don’t need no straight edge! I’ve got Bruce’s instructions re-ThermoSteel etc.. but I’ve got two questions.
(1) The #3 stud is 7/16ths (others 3/8ths) and is not fully into the block, such that the flat spot between the coarse and fine threads extends beyond the manifold – and will require 2 washers (at least) to keep the nut biting into the threaded portion of the stud. Is this OK? (maybe I can answer that myself? Yes – that’s how it was for the last 20 years.)
(2) Bruce says <Use hi-temp Permatex> - Well, OK, I have some “Permatex High-Temp Red RTV Silicone” – but I have no experience of using it – do I put it on both sides of the gasket? Or just the head? Or just the manifold? Also I’m guessing that “less is more” and I don’t want to be slathering it on with a trowel? Some practical Permatex advice please?
One last thought – any advice on refitting the hood? It’s just me and the wife . . . After the slight fight over removing it, I’m guessing the refit is just slow and easy and try and avoid too many cuss words? Maybe flowers and chox?
