Now I know what your going to say, "just replace it, for piece of mind" Here's my dilemma though. This tractor was not a running machine when I got it. I overhauled the engine as it was stuck from being full of rain water. I'm about ready to put it back in and I was taking a last look at things before I plug the engine back in. I've not had to replace a throw out bearing in an model H or any thing of the like so I do not know what play there is in a new bearing. This tractor had a practically brand new clutch in it. The bearing to me looks new with only a slight amount of wear where the pressure plate fingers would have rubbed it. It was fairly clean and you can still see what I would describe as matching marks on that same surface. It's a federal Mogul. My concern is that I can move the inner race side to side within the bearing housing. If I put pressure on the inner race and spin the outer surface everything seems to rotate very smoothly. I'm thinking it's probably good and I'm figuring it was new when the clutch was installed. The play in the inner race bothers me and I just don't know if that same amount of play is present in a new bearing. Wish I could post a picture of the bearing.
I'm not above getting a new one for this but I hate to throw away a perfectly good bearing if I'm just misinterpreting it's condition based on the play I'm finding. I really do think it's new and probably was replaced with the clutch. I'm just not sure about the play. I also don't want to be splitting this thing again to replace these bearings when I could have taken care of it.
Did IH do away with the ability to grease these bearings? There is a bit of grease in the center of the transmission input shaft but I think that is there when the clutch was installed. I do not see a way to grease the throw out bearing or the pilot bearing as you can do on the model H tractors. It appears the throw out bearing probably could accept grease between the inner race and the plastic thing that is also in that area. But I don't see how you could get any grease in the pilot bearing.
Thanks for the help.
