SinkholeRoad
So I m installing new gaskets between the transmission side and the axle housing on my 1950 Farmall M. I am going to make my own gaskets. I have made an observation about the hole on the transmission side near the bottom. It seems obvious to me that the hole is an oil return from the bearing carrier. So if someone making their own gasket did not open the gasket for that hole you would create an oil flow problem. My question is, are their any other concerns about making your own gasket for this location that I should consider?
