Dakota Farmall
I am having tons of carb icing issues on my 1950 Farmall M. I cleaned the carb since the tractor had mostly sat for several years. It has been an exceptionally wet and warm Fall/Winter so far this year. Temps have been generally between +20F to +45F. I understand that this is the perfect scenario for carb icing. It thaws out fairly quickly after the internal icing kills the engine and will start right up again after a few minutes.
I am wondering if I am running it too rich? I turned the main screw on the carb three turns open.
I built a hodgepodge intake preheater (ie a 10" tin can with an 8" piece of flashing riveted to the can and sealed with duct tape) and that did not seem to help. The tin can and flashing extension are open at the bottom. I have a hole cut in the side and a piece of tubing going straight into the intake. Should I enclose the bottom of the "can" surrounding the muffler? I am not sure there would be enough air flow to the engine through the tin can with the bottom more sealed up than open?
If anyone has pictures of their air intake preheater setups, that function well, I would love to see them!
I will try to get a picture of mine posted here. It is fairly crude and made with stuff I had laying around.
Thanks!
Also, to save some well intentioned person the time of a post explaining carb icing, I am familiar...I learned all about carb icing +20 years ago flying little single engine airplanes.
Thanks!
