Hello, i have a 47 Farmall M that has a 12V AC Delco alternator conversion on it. the alternator tested bad a while back so i put a new one on it.
when i start the tractor, the amp meter shows discharge unless i rev the engine way up. then it will kick in and charge the whole time i'm using it.
when i shut it off, same thing again every time i use it.
seems like this shouldnt be necessary. would appreciate any thoughts you have. it has the internal regulator like 1980's GM type products. thank you ! Kent
