Good day,
I own a Ford 2910. I had to replace the fuel tank shutoff strainer because it became clogged. Then, after having cleaned the tank out and then using it for a period of several hours over days, it would not start.
I again replaced the fuel strainer after finding it clogged. I also replaced the fuel filter and fuel line that runs from the fuel tank shutoff to the fuel filter.
I opened the bleeder valve on the fuel pump, turned the engine over and at first fuel came out only in dribbles.
I removed the fuel line at the shutoff valve and shot compressed air into the fuel tank through the shutoff valve to try in dislodge any potential debris.
I attempted to bleed each of the fuel injection lines to clear out any air, but very little fuel came out.
I used starter fluid several times to get the tractor running, but at idle it surged constantly until the engine quit about 10 minutes later. It then would not restart unless using starter fluid.
Current results:
1. When turning over the engine it will not start unless using starter fluid and then will immediately quit running. (Yes, I have the kill switch pushed in.)
2. There is now fuel coming out of the bleeder injection pump about 8-10", but very little fuel coming out of the fuel injection lines.
3. It seems as though the engine is not getting sufficient fuel to run, or air blocking passage; I guess. However, without using starter fluid the engine will not start even though it turns over just fine.
I am frustrated and would appreciate any help you may be able to provide.
Thank you, Rick
Current results:
Thank you, Rick
