I'm looking at a Ford 3000 series TLB and have a few questions on it. From what I've been able to find it's a 66 3500 (or 3550) diesel with a 735 loader and 723 12' back hoe.
Here's the numbers:
Transmission:
6K18-B
35014E
C168760 7B25
Engine:
N246510
Loader:
T9-541
Serial# 510
Hoe:
model 723
T9-500
Serial 1737
The tractor was a stuck motor and would need boring and pistons at a minimum. Supposedly it was running and working fine and was used by a guy to level his house pad and ranch work. Says it wouldn't turn over one day and he never did figure out why. He pulled the head but then got deployed (Navy SEAL) and while he was gone the cover came off the motor and it got rained on. All 3 cylinders have significant rust and would need to be bored but the rest of the tractor looks decent if dirty. The hoses and tires are all pretty rotten, but that's expected. It reads 4175 hours, not sure how accurate that is. The hoe and loader both look very clean, we could only find one place that looks like it was welded. Hydraulic cylinders have some pitting but I think they could be salvaged at least for my uses.
The trans is the select-o-speed unit. Supposedly it all worked, but there's no way to test it and it's been sitting ~10 years.
I can get this thing for $800-1000, if I don't pick it up he's thinking of scrapping it and I hate to see that. On the other hand, I don't really need another project.
My questions:
1) What's involved in getting the engine out and rebuilding it? I've rebuilt pickup diesel and gas engines but never gotten into industrial type stuff. I'd guess it wouldn't be much different other than heavier. Correct?
2) How available are parts? The only info I can find on the 3550 is that is had a 183 CID engine but I can't find any other info on it. Seems like maybe it's a typo and it's actually a 175. It's a 4.2" bore motor.
3) How are these tractors / hoe reputed?
4) What's the chance of the trans having problems? I'm leery cause it looks like an early powershift setup to me, and thus likely to be problematic and expensive to fix....
5) The deal would include a block and crank off a 4000 series, not sure what motor other than it has a 4.4" bore. Would it be worth working this block instead of rebuilding the current motor? Could it even be used?
6) Does anyone have specs on the backhoe / loader? I can't find anything on either.
7) Is there a service manual that covers the industrial units? The ITT manual seems to cover the basics, but the hoe and loader and whatever is different for an industrial tractor is not covered.
Thank you,
~John
Here's the numbers:
Transmission:
6K18-B
35014E
C168760 7B25
Engine:
N246510
Loader:
T9-541
Serial# 510
Hoe:
model 723
T9-500
Serial 1737
My questions:
Thank you,
~John
