SA Eldridge
Appreciate everyone's input... Recently bought a 1978 Ford 3600 gas. It popped/backfired some when rapidly moving throttle, but bought it reasonably. Put a new Zenith carb on it and adjusted throttle linkage to appx. 650 low and 2250 high. Did not adjust carb. It now starts well, seems to run OK not under load and no longer pops/backfires when quickly moving throttle back and forth.
Problem... Put a 6' bush hog on it (raised 10"+ in appx. 20" tall grass) and it pops/backfires some when engaging PTO on bare ground and will pop/backfire/die for some reason while mowing at 2100RPM+. Pulling choke to make it more rich did not keep it from dying, so do not think it is lean. Since it seems to run well not under load, I do not think it is a fuel flow or plugs/points/distributor or timing issue. Seems like a Governor problem? I tried the test where you put on brake, apply 1/2 throttle and try to move Governor for more RPMS and it did not fight me. So, does this mean the Governor is bad? I also tried the test where you disconnect the Governor linkage and watch what governor does in response to throttle. Well, my tractor rev'd 3000+ until I manually grabbed the gov and throttled it down! Was not expecting that, but was not sure what to expect since I am not an expert on old gas tractors. Kinda hard to watch gov in relation to throttle. Will retest when my wife gets home. Thoughts? Thanks! SA
