oldford647986
I have a 1964 ford 4000 Gas with the Select-O-Speed. I have never had an issue with this tractor before but when baling hay last week I clicked down a gear and the tractor just stopped and the PTO disengaged, I have no movement in any gear at all and no PTO. I disengaged the axle and pulled it to my shop to split it figuring the torque limiting clutch let go. Now that its split and have removed the clutch it doesn't look as bad as I expected. on the pressure plate and flywheel there is signs of slipping but the disc is relatively intact still. Is this what one looks like worn out or do i need to dig deeper into the transmission? really don't want to put it it back together and it not work and also don't want to have to tear into the SOS if i don't need to. pictures attached for reference.
