Chieflifegrd
Just bought a farm that has a 420 conveying. The loader has lots of numbers on it, but YT's techs can't make any sense of them. Somebody please help...my front mounted pump has taken a dump and spilled it's lunch all over the ground. When I took the pump off it's the most corroded thing I've ever seen in my life. No numbers are left on the casing that help the YT people. The input shaft seal has lost most of the rubber from the 3 o'clock to 6 o'clock position and it's pushing out every bit that's put in the reservoir almost as quickly as it's put in. Numbers on the loader as follows...
Left post- FoMoCo 291501 F
Left front - LKI
Left inside near bend - Series 19640, Serial 3194
Right front - RK2
Right post - FoMoCo 7705465 F
Is this loader referred to as a "770"? None of the YT techs have had a clue. The only option offered for a 420 looked right and was advised by the YT techs as to be my replacement. It looked exactly right in the pictures, so I ordered it. It is not right. The mounting holes are at least an inch off and the splines on the input shaft are not present on the new pump.
I really needed this tractor up and running, so I decided to trust the YT people and even paid for a 2 day delivery, which ended up being 4 through no fault of UPS. I need this thing up, can somebody with some knowledge please help?
Thanks,
-RL
Left front - LKI
Right front - RK2
Thanks,
-RL
