Ford 5000 clutch and PTO input shaft
nwford
I'm in the process of replacing the clutch in my 74 5100. Found wear on the splines in the drive hub for the PTO and the input shaft E4NN7A684AA. Can I remove this shaft after removing the rockshaft, PTO clutch and the upper rear pto output shaft?
Appears it comes out the rear of the transmission.
Book shows the tractor would need to be split at the clutch housing and the rear center housing to remove this shaft.
No, you'd need to split the tractor because the hydraulic pump drive gear would need to come off to get the bearing and shaft out. No way you could get that done without splitting the tractor.
