I have a Ford 641 with a leak in one of the power steering cylinders on the left side. Fluid is slowly dripping out of the front end, dribbling down the length of the cylinder and then dripping to the ground near the clutch pedal. Power steering still works, but I need to fill the tank every couple days of use.
Is there a seal I need to replace? Or would I need an entire cylinder? Any information would be much appreciated.
Thank you.
Thank you.
