Hey guys,
About 10 years ago I got a 1956 Ford 860 that was surging (rpm would loop high/low). I put the project on the back burner until this year when our field became overgrown with autumn olive bushes and desperately needed to be brushhogged. Surprisingly, letting the tractor sit outside only created more issues and I ended up having to replace the alternator, ignition coil, and rebuild the carburetor. In addition, I converted the electrical to 12V, new spark plugs, points/rotor/condenser. The carburetor adjustments and point gap have been set according to the owners manual and the tractor starts right up and seems to be running well.
My concern is after about an hour of moderate brush hogging I noticed the exhaust was glowing red hot. I can't imagine this is normal and after reading through some forums it seems that the problem may have to do with timing or running lean. I checked the spark plugs and they appear wet so I'm critical of timing. I also noticed that if I shut the tractor off using the keyed ignition the tractor trys its best to keep running and sputters for some time until I pull the choke. Maybe this is normal as originally the tractor wouldn't have a key ignition but it might be a clue for someone more knowledgeable. I've attached a picture of the pipe in a dark barn. I would greatly appreciate anyone's opinion on the matter as this small project is quickly getting out of scope.
Important to note, the elbow after the manifold has a crack right down the center of it and the muffler has it's far share of leaks. These are next to be replaced, but could that be contributing to the problem to this extent?
Thanks in advance,
-Lclear
Thanks in advance,
-Lclear
