Does anyone know what loader/s will fit on my 1955 major, thanks
Thanks for the pics and advice, I will start my search lol.View attachment 64418
FWIW, here's my Power Major, a few years newer. I was thinking it was a Sherman loader, it may be Davis or a Midwest, I wish I knew for sure. The previous owner (now deceased) fitted the dual bucket cylinders.
On top of that most people selling an old loader have no idea what they have or what it fits. As I said in the other thread the only way to be sure is if the seller removed it from the exact tractor you want to install it on. Anything else will require some amount of modification.A loaded question that gets asked frequently.No simple answer. Only a select few will be a direct bolt on. However there are MANY that can be made to fit with little modification.There were of dozens of loader manufacturers. Most made a loader/kit that would fit your tractor. Finding such might be difficult as few were probably made.Easiest is to find something close and make it fit.
To add to what you say, if it requires any mounting brackets see that that those were removed from the tractor and kept with the loader.On top of that most people selling an old loader have no idea what they have or what it fits. As I said in the other thread the only way to be sure is if the seller removed it from the exact tractor you want to install it on. Anything else will require some amount of modification.
True! A Ford 8600 was sold at the spring auction auction with the loader brackets left on.So now the loader is basicly worthless.To add to what you say, if it requires any mounting brackets see that that those were removed from the tractor and kept with the loader.
I Had a paulson on mine ok if not to heavy of jobDoes anyone know what loader/s will fit on my 1955 major, thanks
Which after looking for a few months for an exact fit you eventually realize that the modification is incidental. I have sold two loaders that went onto very different tractors in my neighborhood. Both were adapted each time in just a few days and workingOn top of that most people selling an old loader have no idea what they have or what it fits. As I said in the other thread the only way to be sure is if the seller removed it from the exact tractor you want to install it on. Anything else will require some amount of modification.
If I was looking to mount a loader on my tractor I would be measuring its approximate fit for my tractor. Here is a photo of a 345. The loader would need mounted so the red line on the right would be placed so you could still get on and off the tractor the more it is placed towards the rear the better. Then measure from that point to the front of the tractor. If this would place the front cross piece below the left line any more than a foot and a half in front of the tractor grill than in my opinion that loader is to big for your tractor. Placing the load the loader lifts and carries to far in front of the front axle greatly reduces the load lifting capabilities of the loader in regards to weight transfer from the back of the tractor and increases the load placed on the front axle.Hello All
I have found a DU AL 345 loader and wondered if it would fit my Fordson any ideas? Also it comes with a lift cyclinder rebuild kit, is this a big job to do? Thanks
Was it removed from a Fordson Major? If not, and you're not equipped to perform the metal fabrication to make it fit, then the answer is no.Hello All
Thanks for all the advice.Was it removed from a Fordson Major? If not, and you're not equipped to perform the metal fabrication to make it fit, then the answer is no.
Rebuilding the hydraulic cylinder can be a big job, depending on the design of the cylinder. Some cylinders are held together with long rods. Those are easy. Others have the cap screwed on. Those can be difficult because they require large amounts of torque to unscrew the cap, so you need a giant vise bolted to a heavy bench, large wrenches, and possibly a torch to heat the cylinder. There are other types of cylinders as well which have varying levels of difficulty.
Thank you for this information much appreciated.If I was looking to mount a loader on my tractor I would be measuring its approximate fit for my tractor. Here is a photo of a 345. The loader would need mounted so the red line on the right would be placed so you could still get on and off the tractor the more it is placed towards the rear the better. Then measure from that point to the front of the tractor. If this would place the front cross piece below the left line any more than a foot and a half in front of the tractor grill than in my opinion that loader is to big for your tractor. Placing the load the loader lifts and carries to far in front of the front axle greatly reduces the load lifting capabilities of the loader in regards to weight transfer from the back of the tractor and increases the load placed on the front axle.
