I'm in a bad luck streak. I hand crank my H and for a long time it's been a pain to start when warm. I've heard that could be the condenser, so finally I took the magneto off, replaced the condenser, put it back on. Now I get no spark. The tractor was running fine before this. The only thing is I slightly dropped it when taking the mag off and cracked the rotor. I tried an old rotor I had, as well as the old condenser. Nothing. I went so far as to order a coil and tune-up kit. Put on the new coil, another new condenser, and new rotor. Still nothing. What the heck am I missing?
Impulse sounds fine. Timed to first timing mark. When I tightened up the condenser, maybe I went a bit tight, and I saw the threaded part turning while the condenser case was not. Would that break it?
