I'm guessing the picture below is my solenoid on my MF202. It doesn't look anything like the pictures of the solenoids in the MF202 parts on this website. It's mounted right next to the voltage regulator. Anyway I'm getting nothing (not even a click when pushing the starter button switch. The switch is good. I pulled it out and did a continuity test on it so I assume it's good.
Anyway how do I test that solenoid to see if it good or bad? I removed the three connections and cleaned and filed the wire ends and nuts and washers so, all the connections are good. Any info would be appreciated guys. Oh yeah, my coil is mounted to the block right above the starter where you would normally find a solenoid.
