I know this isn't the place for a ford pickup question, but I also know several members of this site have an excellent knowledge of mechanics. I need some help:
By brother and I are working on a 63 ford pickup 223 6 cyl (electirc wipers). We replaced an almost new fuel pump (probably chinese) because it was not pumping gas. We ordered a new one from Rock auto (for sure chinese) and it isn't pumping either! We know we have gas to where it enters the pump. We disconnected the outflow side to see what was up and nothing coming out. Realizing the fuel pump pumps more at higher rpm we rigged up gas to the carb bypassing the pump. Had it running for 15 or 20 seconds and still no gas coming out the outlet. We took it out. When we pumped it by hand it seemd to have a faintest bit of pressure, but when we put the output end in a glass of water and pumped by hand we could not make a bubble. I have replaced 1 fuel pump in my life on a 353 ford 45 years ago. As I remember it there was no mystery on how to do it. Take one out put the other one in.
These new pumps have very strange arms made up of several pieces of metal bolted together. There is one possibility (other than another bad pump) and that is we have it in upside down. It will fit upside down but we have not run it that way. Facing the engine, the motor turns right. I am not certain but I think these engines have a timing gear and not a chain. If that is so the cam would go left. If that is the case, the arm should be riding on the correct side of the cam lobe. We are hesitant to try running it with the pump upside down. Just some idea as to how much fuel we should expect to see come out when the engine is turned over would be helpful. Thanks all for your consideration. I could go to the truck page, but I know what a smart bunch we have here. (excluding me)
