HVFDfirefighter
I had taken the radiator off my 1952 Farmall Super A Serial number 336453. Got the radiator flushed out. Put all back together, no leaks! Started the tractor up after working on the carb. Let it run for a bit and I noticed antifreeze dripping on the floor. Shut it off, It is dripping out of the top seam and onto the fan slinging it all over. I am thinking I need a new radiator. Mine measures 17.5 wide, 21.25 tall from bottom to top of neck with 3/4 inch neck. Both inlet and outlet pipes are 2". I have noticed a lot of difference in price. some for $199, some as high as $500. Not sure which one to get. Here is a picture of the tag on the current radiator. I really want to try to keep it as cheap as possible. I have also noticed the new ones do not include the fan shroud. My shroud looks good. Is that something I can take off old and put on new? Bolted on?
