Anonymous-0
Hey Roger, I"m so sorry to bother you again, but my disc on my 325 won"t load?? I took apart the valves and cleaned and resurfaced them like I did the ones on the 5120,before I did all that the hyd.unloader was leakin, so in the process of cleaning all the valves(one at a time)I took apart the hyd unloader, now it isn"t loading and unloading properly??and I have air comming out of the breather after the compressor shuts off?If I disconnect the unloader line going to the towers, it pumps up OK, but when it shuts off, the pop-off valve on the intercooler rattles a little?As soon as I connect the line back to the towers you can hear them unload,and then you can hear air comming out of the breather.I think most of my, if not all of my problems are in the hyd unloader.What do you think?Also how tight are the collar nuts supposed to be under the towers?I just tighented them down to a little more than zero clearance?All the valves were in pretty good shape, but they were real dirty.There was a little water in the high pressure valves(high pressure piston side?)I"m not sure what all this stuff is called so bear with me please.When I took apart the hyd unloader it had some dirt on top of the piston lookin thing that gets the air from the tank commin in?It"s still leaking oil pretty bad around where it goes together at the bottom where the diaphram is located.Where the air from the tank goes in to the hyd unloader there seems to be a brass screen of some sort?If I could have gotten my cd to load I might have not bothered you again, but I"m desperate, this is MY compressor, and I need it bad!!! Please help me, and GOD blesss
