37chief
- Location
- California
I have a pressure control valve. Mounted to the transmission housing, on the right side next to the main hydraulic filter, on the lower side of the tractor. There is a steel pressure tube going to this valve, Then a rubber pressure hose up to a bank, of three hand valves mounted on the rear fender. I never use. The valves go to nothing. I have a leak from the pressure control valve where it connects to he outside of the transmission. Can I just cap off the steel pressure line to the pressure control valve? The way see it is, all this valve does is control the pressure from the hand valves on the fender, or does this valve control the main tractor hydraulic pressure? Any thoughts? Stan
