John deere 60 wiring
Ernie000
I need help with a easy wiring diagram for a 1954 John deere 60 12 volt positive ground with generator voltage regulator distrubator coil and amm meter no ignition switch thanks for any help available
(quoted from post at 12:38:26 04/16/23) I need help with a easy wiring diagram for a 1954 John deere 60 12 volt positive ground with generator voltage regulator distrubator coil and amm meter no ignition switch thanks for any help available
how is coil wired .??
On 12 volt tractors that used a 6 volt coil with an external ballast plus ballast by pass circuit there are
2 wires on each side of coil, did you find the wiring diagram I linked below ??
John T
(quoted from post at 15:38:26 04/16/23) I need help with a easy wiring diagram for a 1954 John deere 60 12 volt positive ground with generator voltage regulator distrubator coil and amm meter no ignition switch thanks for any help available
no ignition switch ".... hummmm,...how do you stop it from running?
(quoted from post at 17:35:40 04/16/23)
got it and figured out thanks so much
(quoted from post at 04:31:33 04/17/23)
Soooo....what did you find out? Inquiring minds would like to know.
